Magic Magnet
Yeah the cheaper lithiums were perfect for me as my town is 1 sq mile. My batteries went bad so I upgraded. It might be 2 weeks between charges for me given how few miles I drive even though I drive it every day
Thanks.. it really is good information.
…and, for the privilege of having 40% of your electrons unwilling to earn their keep, you are totting around about 400 pounds of next years secret flavor enhancer for imported Chinese dog food.
Sorry I haven’t had another update. I painted my gem and somehow caused an electrical problem. I keep blowing the display fuse. So it hasn’t been drivable. I am going to again try to find the wire that is causing it today.
Update. I’m at 18.2 miles now with 56% charge left. But I accidentally left the lights on all night last night.
Ok, kewl… How hard did you run it? So you might think to expect 40 + Mike range ??
Now at 29% and 27.7 miles. I have a lead foot and do 25 everywhere
Ok…. So if I follow you, we are looking at about a 30 Mile range under “get out of my way” conditions with the lights on. That’s about what I expected. Might be interesting to see how that changes as the battery gets older . If you notice anything else about the battery that we might be interested in, please feel to post. Thanks
I have a Ford Think and interested in the magnet, I just installed lithium and running 15” wheels, topping out at 28 mph.
I don’t have feedback from Th!nk users. It may or may not be useful. Some cars will run without speed sensor. The only advantage then would be restoring speedometer function, albiet not accurately.
My speedometer on the cart isn’t working properly, showing 8mph at top speed. I’ve been using phone app. What would you suggest to get 5+ more mph?
Fix speedometer first.
In theory, if speedo (and controller) believes the car is only going 8 mph and you are actually going 28(gps), then the controller is not limiting speed. There is something else holding your car back.
You say you are running 15 in tall wheels? (total??)
That is probably your limit right there. My calculations put the motor at 6500 rpm. (given the gearbox ratio of 10.3)
If your thunk is “surgung” at its maximum speed, then you are being held back by the “Maximum Oversoeed” parameter in the E2 controller. You may be able to go faster by raising that parameter or possibly using an MM.
If your thunk runs smooth at top speed, thats all your drive tran will do. You will need higher voltage to the motor, taller tires or taller gears.
For s Think, taking the stock 4hp GE motor over 6k rpm may be risky. Not sure what bearings were used in it. D&D Systems has a 6.5 or 7hp think motor that can spin redlined at about 8500 rpm
That’s about the safe limit for the spicer gearbix stock bearings too.
A note on programming the controller in a think, it is an E2 not a T2. Do not use the GEM T2 mdb file. There are subtle differenxes in the controller. Parameter order is different. I should have a cooy of the E2 file somewhere. PM me if you need it.
@AssyRequired iirc, thinks had 10.0:1 gearboxes. Its a minor difference, but remember they were RWD.
The 4hp GE motor was slighty didferent than the short ge that Gem used. In not sure if they are cross compatable.
And now, after all this talk about the Da Thunk, its time for a musical interlude of Da Funk from our sponsors. Everyone please sing along. You know the words…
Good afternoon Dave, I would like to purchase a magic magnet
$150 to PayPal.Me
Thank you,
Dave
Sent pay pal & info :ok_hand:
Good Morning Dave, New to the Forum. I just purchase a 2002 GEM-4 with new Lithium Batteries. I would like to Purchase the Magic Magnet from you for this car. Please let me the cost and how the best way to pay you would be as well as any information you need from me for shipping or what have you.
Thank you in advance.
Paypal $150
tnx DAve
Thank you, the wife has PayPal, we will get done and sent you along with the shipping address
Thank you
