First, the fun part… the car. It’s a custom built mid-engine vehicle with the general chassis design based off a “locust” custom/kit car. Mine has been lenthened and widened for purposes of comfort and design of the body. It’s mid engine as it uses the drivetrain of an MR2 but still awaits the electric motor and other components to be complete. Thats where I need a bit of direction.
Roughly I’m looking at about 1000 lbs. now but not official by any means; no est. yet for the fiberglass body, batteries, motor, controller, ect… It’s unlike the typical “locust” b/c it’s a fully enclosed 2-seater with a full body and resembles a street car more than a roadster. The majority of host parts having come from a late 80’s MR2. The batteries will be held on the front half of the vehicle and can be modified to fit as many batteries as needed.
I found this kit that looks good to me, but hoping to save a little by getting some stuff from second hand sources. The kit is a 72-144 Volt - Warp Medium Size Vehicle Kit from electricvehilesusa.com. It claims a 3000lb max weight which is more than enough for me. Using it at 144 volts it claims a range of 40-50 miles and a top speed of 90 mph. This is ideal for my application, and the kit comes in at $5700. My main questions are at the bottom…
Here are the specs of what it includes and it’s associated value. The kit itself goes into further detail on the webpage mentions above if theres a question as to the spec of any of the items mentions below;
1 of Battery Charger Zivan NG3 120V-288VDC 230VAC input ($1,350.00 value!)
1 of PakTrakr600EV Package ($149.95 value!)
1 of PakTrakr 6 Battery Remote ($68.95 value!)
12 of Battery Terminal Universal Heavy Duty 1 ga to 4/0 ga ($35.40 value!)
20 of Cable 2/0 Gauge - Black ($139.00 value!)
20 of Cable 2/0 Gauge - Red ($139.00 value!)
1 of Controller, Kelly 24-144 Volt 250amp ($998.00 value!)
1 of Contactor, SW-200CW W/ Blowouts 12 Volt Coil ($229.95 value!)
1 of Contactor Albright Reversing SW202-84, 12 VDC Coils With Blowouts ($349.50 value!)
5 of Lug Straight 2/0 GA 5/16" Hole ($14.95 value!)
10 of Lug Straight 2/0 GA 3/8" Hole ($29.90 value!)
1 of Motor WarP 9" Up to 192 Volts Dbl 1.125" CE Shaft ($1,800.00 value!)
1 of Switch Power Cutoff - Heavy Duty 5000 Amp ($89.95 value!)
1 of Throttle PB-6 0-5K Lever ($89.95 value!)
What substitutes could be made with these parts? Such as, what alternative motors (both size and specs) could be used if I’m going to do as much as possible on a budget using ebay and other second hand sources to get parts? Please be semi-specific as I’m still pretty new to EV’s but will be starting to get parts soon!
What could be excluded if buying these parts sperately, or as I expect, is everything on the list a must have?
Does the kit mentioned above really have the potential to provide the specs it implies? What could be added or changed to increase range and still maintain the speed?
I know the batteries are alot of the equation so, what and how many batteries would be ideal for this setup? As mentions above, I would like to keep the speed this package claims but wouldn’t be against an increased distance if possible, haha. For now I expect to stick with sealed lead batteries but open to other suggestions if it warrants the additon cost.
Besides the batteries and adaptor plate, what else is needed to make a vehicle using this kit come to life?
