Does anyone have one for sale or a recommendation on getting it repaired.
If I switch to delta charger the plugs don’t look the same?
Where are you located? There are a couple of fuses inside these, one at the VAC input side and one larger one handling the output. There is also a known heating problem near that input fuse area which has caused connector issues.
I have one, freshly factory reworked and updated that I want to move. Please let me know at 315-567-6308
Where is the other fuse? I found the large one, but can’t seem to find the other one on the Zivan charger board.
You have one of the soldered on fuses and are really not easily replaceable without a bunch of work and special equipment.
That is not saying the fuse is the problem and/or the solution. They usually blow for a reason. That’s why this thing is buried so deep.
Agreed. It’s not user replaceable for a reason. @igeek207 best to move on with a replacement for the zivan.
