This was an idea that Dave @Inwo came up with at some point in the past and I was the first ̶i̶d̶i̶o̶t̶ scientific pioneer willing to test it…
… Adding an extra battery after the main contactor, so that only the high amperage terminals on the controller see the extra voltage. Translation, no voltage shunt needed for control power and that somehow changes how the controller sees things and the car performs and I’m gonna let Dave explain that part because he’s an electronics genius and I just fix stuff.
Yes, it’s really similar to Rodney @Old_Houseboater 7th battery 84V hack. Just different location, no shunt, and no disconnecting batteries to charge the main bank with a stock charger, since the contactor is open during charging and the two battery banks are isolated at that point. \
Took a while to get around to this because I decided to fix an input shaft bumper. This lead me to discovering I had a worn out input shaft with bad bearings and wounded motor. A new input shaft, new bearings, new oil seal, a new motor that didn’t freaking fit properly and a few emails to Rodney for some invaluable experience and advice and we’re back… (hide the sheep)
So here’s the idea, the circled 12v battery is an extra pack that we added after the contactor. It only provides extra power to the motor and only when the motor is in use.
So here’s how we did this (pay no attention to the man behind the curtain).
Tear the dash apart, find the output connector on the contactor.
Run a pair of new battery cables to wherever you plan to locate the new battery. I used a pair of 2 AWG and sleeved them in polyethylene wire loom braiding then installed connectors.
I have am '02 longback, the pack is going in the toolbox I have mounted in the bed.
(Getting dizzy yet from the pointless amateur Hitchcockan camera angles yet?)
Disconnect the output lead (that runs to B+) and connect it to what will become the battery + connection from the booster battery. Wrap it with proper insulating tape - this is going to see 300+ amps, you need to use good quality splicing tape, the 97-cent rolls of electrical tape just aren’t going to cut it here. This one got varnished cambric, 130C and then 33+.
Hook up the lead that will go back to battery minus to the contactor output.
Well, hook it up…
Battery hooked up and fast charger hooked up to the battery.
I wanted a bulkhead charger mount for the booster battery charger.
How cute…
Not 1.21 jiggawats, but hey, it works.
Remember, safety first. Always obey safety warning signs, as you might not get a second chance.
So with the wham-bam-bonus battery pack installed, and an R4F 7.5 hp motor, with 6 FLA batteries, 21" tires on stock 12" pizza cutter rims in a heavy azz 02 longback, I’m hitting 36-37 in the sprints with a good charge.
Super easy install, I spent more time figuring out how I wanted to install it and running around for the last minute extra part, than I did installing it.
