One of the top questions I get asked is how to increase a Gem’s range . So I want to share a few ways to do it . Some are easy and cheap , some not .
Increase the tire pressure . Most Gems I get in the tire pressure is low . Increasing it to 35psi will increase range and top speed . I did a test on flat ground . Gem had 21psi in the tires , increased it to 35 psi and picked up 2 mph .
Keep your speed down , This is No fun but Gem’s are like cars . The faster you drive the lower your MPG or in this case , MIles per Kilowatt ?
Increase it’s regenerative braking . Regenerative braking takes your speed and converts back into energy and puts it in your battery . Without it you are taking all that energy and wasting it on braking .Tesla’s have a lot of this programmed in and they call it one foot driving. Once you have it you don’t want to be without it . Gem has it but from the factory it is set on low . Also for you pre 2005 guys with crappy drum brakes , This will help slow you down and probably eliminate the need for a disc brake upgrade .
When programming a controller keep #7 as high as possible . Reducing field current (#7) will increase a shunt motors top rpm . For those looking for more top speed you want to do this but it takes more amps from your battery . If you have all the top speed you need , Especially the lithium guys don’t reduce this number . On my personal gem I increased it . Because my Gem has high voltage lithium the top speed is more than i need so no reason to reduce #7 . If you drive your Gem and it surges at top speed your #7 is too low.
Increase battery voltage . Raising your pack voltage increases speed and range . You can do the 7th battery hack for lead or add additional cells for lithium . If you have a 25s lithium pack increasing it to 26 , 27 or 28s will increase range . Don’t forget to increase the chargers voltage to compensate .
Replace your batteries with higher amp hour ones . Lead and lithium come in higher capacities so when you put in new batteries put in bigger ones . The DeltaQ charger can handle them .
Get the lead out ! The number one thing you can do to a Gem is lithium . It will make it faster ( with a stock motor 40mph is possible ) It will go farther , Mine is probably 50+ miles . And it will get much lighter . A stock pack with hardware weighs about 425 lbs . A lithium pack 85 to 150 lbs . A stock E4 weighs about 1200 lbs. Take out 300 lbs and you have removed 25% of its weight . That in itself makes it accelerate faster , handle better and stop much quicker . Add it with all the other benefits of lithium and it is the best thing you can do to a Gem .
Hope this helps some of you out . I always enjoy the comments .
Kinghappy , The Godfather of Lithium .
