Current Action Item List
Back Seat Upper Bucket Seat Mounts
Back Seat Lower Bucket Seat Mounts
Back Seat swing or slide out slides for rear compartment access ease
Measure and build/modify waterproof enclosure for 4 24v Volt modules in rear compartment
Measure and build/modify waterproof enclosure for front under hood area
Mount Delta-q 922-9654 DCI converter in hood area enclosure
Identify and procure Bluetooth BMS and install
Wire DCI 12v switched power to ignition switch
Wire DCI 12v always on to Sonoff dc smart switch
ReHome 12v lights and accessories to DCI 12v switched power
Wire Bluetooth Stereo Amp to Sonoff DC smart switch
Mount Bluetooth Amp in Front enclosure
Explore contractors to electrically separate 24v modules and charge via solar and boost controllers.
Figure out why rear view mirror backup camera no longer displaying video
Measure steering column, joints, and tie rods and find after market power assist or power steering upgrade
Measure angles and lengths of coil over spring mounts and calculate size requirements and find replacements
Measure and figure out how to calculate disc brake sizing and find replacement
Install Windows emulator on dash control tablet and install GE Software
Mount tablet in dash and wire charge cable to switches 12v
Add additional Sonoff 12v switches and replace all steering column switches
-Ignition
-headlights
-high/low speed
-Forward/Reverse/Neutral
-wipers
Dial in regen braking
Explore using servos or power trunk/hatch lifts for hood, dash, possibly rear access
Explore 4 wheel drive, dual motor options
Make it faster
