I have two more modules and can make two 4p12 sets.
All my work on this one gone, but water over the dam. I need to make a useable battery out of what I have.
120ah total 88v nominal.
Two of these:
12.5 x 15 x 8
End to end 30 x 12.5 x 8 total.
I used three 16s Chevy spark batteries that I converted to 8s and then hooked them up in series to create a 24s pack. I had to remove the center seat support bracket to make them fit. In my eyes the bracket isn’t needed anyways. The seat frame is quite stout.
Due to constant voltage output aggressive active balancing doesn’t work well.
Shunt balancing over 3.6 volt is what I use. Discrete balancers, one on each cell. What is center to center spacing of your cells?
I love these for balancing lifepo4. Green indicator shows they are connected and working. When cell reaches 3.65v red led illuminates and draws 500ma current. Remains on after charging to bring any rogue cells down to 3.6v.
That’s what I do, and recommend. It will not replace a bms with a lvc and hvc, but lfp are pretty stable and safe.
The kiss of these discrete balancers is what makes lfp attractive. IMO
ps.
IMHO
Balancing lfp any place except “over charged” is a fools errand. A balancer can only attempt to keep voltages the same. Lfp are pretty much the same volts through their useful range.
