These lithium packs will give your Think a 40 to 50 mile range . I have been supplying them to Gem owners and have had limited availability . Now have a few more in stock and can offer them to Think owners . These are New battery packs made by LG chem . Base version is a 20spack @ 82v but can be upped to 24s and 96v ( I run 96v in my personal Gem) . These packs are 180ah and weigh 140lbs total . A stock lead packs weighs about 400lbs .
This upgrade will make your Think accelerate much faster , climb hills at higher speeds and significantly increase range . In most cases your Think will perform so well with your stock motor you will not need to upgrade it .Your Deltaq charger will need to be reprogrammed for lithium . And I would recommend using a BMS . Multiple Gem owners are using a 400A , 20s , bluetooth one off of Ebay and have been very happy ($125) .
We have dozens of Gems running this setup .
The pack have 2 modules . These are pictures showing dimensions with the modules stacked on top of each other . They can also be use side by side .
The packs prepped and ready for install are $2200 .
