I don’t have a modern either - I only have the classic on gear end and modern on hub end.
Correct solid shaft:
“15.75” should be the length of the solid shaft spline end to spline end"
Trim gearbox is a a bit wider so if the Comex shaft is larger might be ok
The one shown is way to short obviously. You sending an oem shaft and measuring the team should be the last puzzle pieces.
Grant could measure the team for me as well.
I’ve found 2 gearbox’s in the wrecked car but they are bad. I’m gonna see if I can make one out of 2 and I’ll send you the other one to play.
I think one of them has some missing input shaft teeth. And the other one some bearings.
The shaft width is all I really need, until I find something that fits.
That is measured between the ends of output shafts.
