Yeah welded by Rodney
It looks like the base speed of the 5kw motor is a winner for high speed.
8kw kinetek
49v
163a
3090 rpm
105hz x 60 = 6,300rpm
8kw
5kw gem
30v
113a
2000rpm
133hz x 60 = 7,980rpm
5kw
6.5kw gem
30v
150a
2000rpm
100hz x 60 = 6,000rpm
6.5kw
If Scott doesn’t get the pmac 6:1 car working, i may need to buy your tranny setup, so Ernie can test it in the E2.
That’s the only access i have to shafts.
You are not using it correct?
I want in on the pmac testing. I was going to build up to it starting with stock. I’ll start a thread as soon as I get my hands on the car.
Scotty’s pmac is still on my garage…unless he has another one.
I almost hope it doesn’t work for Scott now.
I can buy Gabes for you in any case.
10:35 and 5k rpm. Possibly 6k or 6.5k rpm bursts.
40mph is faster than you dare drive an e2 without sway bars.
I peaked my blue one at 35mph. Crazy stupid.
They are still in my car everything oem but the Gearbox car is on jacks since 1 year so I use the speedometer now that is accurate.
I would like to try a 12.1 if you can find me one we can swap, I’ll include the shafts they are the only pair on the field
I want to keep it for a bit, since it’s installed I want to crank the torque up and give it a try repro torque mod and 10.35 and 5kW
It did 40mph with oem torque (Speedo showing 23moh) so electronically had more to go, but I think the Oem torque at 6400 rpm was too low so motor was not getting any juice. I will mod the torque and see what happens
I want an 8.675309:1 tansmission.
Let me see if i can talk Grant out of his later. At least as a loaner.
Both ways loan. We can all get it out of our system.
could it be a case of because mike KC could not get his to work I’m some how I’m doomed?
Mine worked. It justed whined and I did not like it.
Plus I remade my half shafts .75” to short.
FYI - you have to grind out some of the mounting bracket to get the PMAC to fit.
By the way your input here is like how Binks fucked up Star Wars LO LO LOL
That’s new. Grant isn’t doing pmac, but Scott and Ernie need to know.
What car did you fit it in?
My 2016
It’s the classic gears built by Rodney just like gabes.
You were MIA for his last pass through here and he was pretty hot on having one. I gave him the one i had here (from Dave’s inventory).
So you are good on keeping that one. (I think)
Tell Scotty to get it running now. No need to wait for gears.
I figure if we can get it running stable up to 35 mph in the e2, I can throw it in my e4 for further testing… or sway bars… need to look at grants thread more closely.
I’m up in the OC the first weekend in March, I can give you the one in my garage.
Grant, will you lend your 12:1 for pmac testing?
Dang, Gabe won’t part with his 10:1 yet.
Unless Gabe can borrow the 12:1 and send Ernie the 10:1.
Mesa love Grant muchly!
