I completed my SDI-22 lithium install last month (with Magic Magnet) on my 2008 e4. Just prior to that I had my 7.0hp GE motor rebuilt and purchased a new gearbox spline shaft kit from @Old_Houseboater because my original seal was weeping oil. The kit contained a new shaft, bearing, seal, and motor bump stop. I’ve driven the car around 29 KM total (switched to KM due to the Magic Magnet). All was well until last night I noticed a big leak on my floor coming from the gearbox. I removed the motor and saw a complete mess.
I’ve gotten the car up to as high as 40 MPH on a flat section of road (indicated as 40 KPH because of the Magic Magnet). Is this speed too high for this gearbox? Why did my brand new spline shaft seal fail? Did the faster rotation of the shaft damage the seal? Is there greater pressure in the gearbox now that the gears are spinning faster (not sure if that’s a thing or not)? My original shaft had a sealed bearing, but the new shaft I purchased has an open bearing which requires a separate rubber seal.
@Inwo, @AssyRequired, @LithiumGods – you guys all played a part in my rebuild so I would appreciate your thoughts if you have any.
Sean
