Hello all,
I just figured i would start a new thread on this with my question…
One of my bulbs burnt out but as it has been discussed before, the headlights as is are pretty bleak. I bought a H3 LED and installed it. They fit in the socket with a small mod. They are longer but that does not seem to be a problem seating all the way in. Its not night yet, but when i compared the old vs the new it does seem as the old reflects better off the mirror backing more fully. The LED seems to miss a lot of it. Now my hope is that at night it will give a much brighter beam but also wider and maybe that is what i am seeing so its not so focused. In side by side on the bench you can see that the LED starts a lot further from the socket which could mean it wont reflect as well off the back…dunno…Yet…
Anyone have thoughts or tried a good LED bulb in the old housings?
If it does not do better, i am considering figuring out a way to hold the bulb farther out by maybe adding a rubber washer or something. But then there will only be that screw holding it in, vs the screw AND the overlapping tab opposite of the screw,
Hmmmmmm
