I’ve looked through the forum but havent found and satisfactory answers. NEV sells bulbs for the headlamps… (Someone mentioned H2) and didn’
These look visually similar:
I’m still really happy with these Rigid LED lights.
Are you running the LED’s off the normal battery harness? I have heard some adding anoither battery for stereo and lighting.
The LEDs are wired in using the factory light harness. I don’t have a separate battery system in my cart. If I’m not mistaken the LEDs draw less power than the factory bulbs.
You can defiantly use the factory harness/wiring. LED’s will use 1/3 the watts of your factory bulbs.
One of my headlight bulbs just went down. As everyone says they are not a great night for driving. So after a look around on this site, and the web it appears the headlights are actually fog lights. Correct?
If so are folks who want to use the stock housing having success using LED H3 bulbs in the housing?
Do they perform on the road better?
I found these…
