Hello All,
If I wanted to put my geme4 in my enclosed trailer, I will need to reduce the height by 4". If I remove my 12" tires and rims and just used 10" rim only, I assume I can drive it into the enclosed trailer. I think the rims are a 4x100 lug pattern and perhaps a golfcart rim will work. Any thoughts? the car is at my 2nd home 300 miles away and if i need to work on it, I can bring it home
thanks
Chuck
Golf car rims are the correct bolt pattern, but will likely cause clearance issues with the suspension because they are much wider.
Daniel
Thanks and Happy Easter. I will have to do a little more research
Chuck
I have a quad
The GemGuy - Tires & Wheels for Gem Cars
All Terrain 22x8x10" with Steel Wheels
All Terrain 22x11c10 with Steel Wheels
All Terrain 22x8x10 with Aluminum Wheels
All Terrain 22x11x10 with Aluminum Wheels
