I don’t think the switches are under engineered, just over priced.
Have there been many failures?
Someone in the past may have flipped the switch under load.
Also some switches that look like breakers have a fusable link inside as a redundant safety feature.
The dash disconnect is nice. More readily accessible.
Remember the one you’re replacing has a 10,000 amp ic @ 80 volts.
[quote=OLD HOUSEBOATER;29767]About 280 at 60 volts. About 22 HP or at 80% 18 HP at the wheels.
This is with me alone in the cart on flat ground.
In my opinion these puppy’s should be standard issue on modified carts. More so for you guys in the hills.[/quote]
Those numbers make me question even more the capacity of the disconnect switch when you are pulling almost three times its rating. I do not consider the switch smoking hot to be a “safety” feature. The switch I’m going to use is rated at 300 continuous, 500 intermittent and 900 peak. I am of the opinion the fuse is supposed to be what goes when things are out of control but having appropriately rated equipment in the circuit will only improve safety and efficiency.
The only issue then would be keeping the shunt cool. Not insurmountable.
The other easy option is make it read 1/2. That is good enough for me. Not too pretty, but until someone finds a higher amp model? The wireless part is very attractive to me.
[quote=Inwo;29802]That’s without modification.
200 amp model.
The other easy option is make it read 1/2. That is good enough for me. Not too pretty, but until someone finds a higher amp model? The wireless part is very attractive to me.[/quote]
you know what if we took the output and ran it through like an RPi2/3 to do the calculations and display it out correctly? I was thinking about this the other night with an embedded controller doing corrections would not be all that hard to do.
Put shunt in circuit and connect 1 wire to +72.
That’s it.
The other wires are my data logger.
It won’t be long before someone upgrades it.
Out for a ride to see how hot the shunt gets.[/quote]
would not be hard to add a heat sync to it if this works out, but you and I should talk about my other idea, might take all of these gadgets and turn it into one box…
Shunt heat is a non issue. Its a chunk of metal and has insignificant resistance. You guys are looking for a pimple on an ants ass. Common get serious.
To some degree (no punn intended) I agree but if he was getting it really hot it puts heat stress on the battery terminal which can lead to problems with the battery itself as you have the weight hanging off the terminal; I have seen this in UPS systems and it takes a $$$ battery and makes it a core charge…
