I had my speed controller rebuilt, and my speedometer shows I’m going 25 but are radar in are parked shows only 16 - 17 mph. I have 205/50/10" tired on my 2000 gem , please help. Could they had rebuild the speed controller wrong. Thanks Al.
How fast in turf mode?
I never check that on the street I can do that now , I will post asap when I get back in the house
Ok I couldn’t get a reading on the radar maybe because I was going slow. The speedometer showed that I was going 17 miles per hour in tiff mode and 27 mph in road mode. ?
Ok, that works then. Must have the controller programmed for the wrong ratio.
Do you have the handset?
Did it read correct before?
I don’t have a handset, and when I bought it it needed to be rebuilt because the cart didn’t move after the new batteies in it.
See what Rodney say’s I guess.
If you don’t want to send it back, or can’t get it reprogrammed, I have something new you can try.
I’m going to talk to the guy , that sent it in and see what he what’s to do. I will let you know.
Its probably programmed for 12 inch rims with 21 1/2 inch diameter tires or bigger. In any event program needs to reflect installed gear box and tire diameter.
i will find out tomorrow, I hope they have records how the company programmed it.
If not, I can loan you a handset, and Rodney can tell you what to punch in.
Need to know: Year, Model, Controller model #, Gear Box ratio, motor make/model, and tire diameter. Stock magnet or performance?
You could use a GPS to gauge speed instead of radar.
Russ
The best is just getting a gps device in your Gem with that it can tell you the actually speed
25 BUCKS ON EBAY FOR GPS SPEEDO
