Rodney sent you an IM.
Greg
Greg
[quote=OLD HOUSEBOATER;29592]
Any how IssaquahWA1979 has a 2005 the same set up with a RFF motor and were going to find out what happens this week[/quote]
I am having some communications issues with my controller that I hope to have resolved tonight in which case I will be able to get some testing done. Sorry for the delay.
OK here are the stock settings that my controller has in it for reference…
Function Name : OriginalE2GEM
ControlType : 353T3
SoftwareID : GL RevisionID : TL Extended RevisionID : Setting Details
F.No. Function Description Counts Value Units
1 MPH Scaling/Not Used 0 0 Cnts
2 Creep Speed 0 0 Cnts
3 Controlled Acceleration 12 12 Cnts
4 Max Armature Current Limit 218 218 Cnts
5 Plugging Current Limit 50 50 Cnts
6 Armature Deceleration Rate 50 50 Cnts
7 Minimum Field Current 4 4 Cnts
8 Maximum Field Current 255 255 Cnts
9 Regen Armature Current 218 218 Cnts
10 Regen Maximum Field Curre 170 170 Cnts
11 Turf Speed Limit 102 102 Cnts
12 Reverse Speed Limit 102 102 Cnts
14 IR Compensation/Not Used 3 3 Cnts
15 Battery Volts 72 72 Cnts
17 Pedal Down Field Rate Gain 5 5 Cnts
19 Pedal Down Regen Decel Rate 10 10 Cnts
20 Pedal Up Regen Decel Rate 128 128 Cnts
21 MPH Overspeed/Top Speed Regula 245 245 Cnts
23 Error Compensation 10 10 Cnts
24 Field Weakening Start 1 1 Cnts
25 Monitor 0 0 Cnts
26 Ratio of Field to Armature 0 0 Cnts
13 Rolling Radius in Inches 86 86 Cnts
16 Gear Ratio in Tenths 103 103 Cnts
18 Pedal Down Field Rate Offset 255 255 Cnts
If you hava a GPS check and log performance and then change #4 and #21 to 255
check performance. Then add Magic Magnet. and check performance again.
[quote=OLD HOUSEBOATER;29665]If you hava a GPS check and log performance and then change #4 and #21 to 255
check performance. Then add Magic Magnet. and check performance again.[/quote]
I plan to do this later today so long as it I not pouring down rain…
took the cart out on a full charge this evening with the stock programming, on flat ground GPS said 26mph. Coming down the hill I got up to 32mph
I cannot seem to write the new settings to the software for an unknown reason it tells me device mismatch unknown configuration even though I loaded the config and it reads just fine.
The other issue was coming back the cart was slowing down a bit and when I pulled in the batteries were down to 73.2v which seems really quick discharge for new 155ah batteries.
Looks like you’re running into the same problems I’ve come up against. Have you tried the MM with the stock settings? and if so did it increase your speed?
Most I can get out of mine is 29mph with stock motor, but larger tires helped.
Thanks for your input.
Greg
[quote=spider445;29671]Looks like you’re running into the same problems I’ve come up against. Have you tried the MM with the stock settings? and if so did it increase your speed?
Greg[/quote]
As soon as I get the controller programmed I will know more that has been a challenge all in it’s own.
How are you communicating with controller?
I have the GE Sentry software
Are you using a USB to serial adapter, or does your computer have a serial port?
Some adapters won’t work, I’ve found.
Never mind. I see you have other problem.
Did you save the downloaded file?
[quote=Inwo;29688]Are you using a USB to serial adapter, or does your computer have a serial port?
Some adapters won’t work, I’ve found.[/quote]
I am using a high end converter however I am able to read error codes and the config which I have confirmed with the company that I purchased the software. He has been extremely helpful and gave me some things to try tonight when I get home.
If you use the MM without making any changes to the T 3, it will tell you if it’s working or not. When I tried it on mine I saw no changes, I then put it on my brother-in laws Club Car with early GE IQ motor and speed increased 5-6 mph putting a big smile on his face. If possible it would be nice to know if it works in your stock setting.
Greg
Should have your tachometer today.
Similar to this.
This should work on club car too, if you want to check RPMs.
Hope our luck changes.
Dave,
Got them this afternoon will give them a try in a few days have family in. I’ll post an update.
On a side note to other members on the forum, have no reservations in dealing with Dave, he is a top notch gentleman who stands behind his products 100 percent without question and will work with you, if you might have an issue. Nice to see someone stand behind his products!
Greg
Do you get more speed with #4 set at a lower value say 200 or 175?
Rodney,
Haven’t tried that yet, but will give it a shot later this week, also will hook-up the new MM with tach that Dave sent and get some RPM readings for you also.
well before I toasted the disconnect switch I was able to get 32mph on the slight downhill section of road with the MM installed. I am trying to figure out how I want to not replace the swith with something that will simply fail again for $80 so I can resume testing.
Piece of barb wire?
Since your in a hilly area strongly suggest you invest in an amp meter. 15 bucks invested can tell you a lot.
http://www.ebay.com/itm/171179319949?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Rodney,
whats the highest amp draw you have measured in your cart ?
