Leaving for 7 months out of state. What should I do for my 5 year old gel dry batteries?
I will set the lever to “OFF” for the batteries. Should I have a someone here plug the cord in every month?
Does the off position preserve storage in the batteries at all? Can I charge the batteries with the lever to "OFF? or does it have to be in the “ON” position?
Buy a heavy duty plug in electric timer. 15amp. Set it to turn on for 8-10 hours once every 7 days. Plug the cart in to it and it into the wall outlet. Leave the disconnect in the ON position. If you set it to off, the batteries can’t charge.
My opinion. If batteries (any) won’t hold a charge with switch off for a year, they need to be replaced.
Great Idea. Beats having my relatives plug it in every so often.
I use 2 timers. A one week timer set for one day of a week. I then plug A 1 day timer into that timer and set it for 8 hours. Then plug the Gem into that timer .That will run the charger for 8 hours every 3 weeks.
Forgot to tell you to set the 1 week timer to run 8 hours on that 1 day a week.
Great tip because I wouldn’t know the amount of time. Thanks
