is there a maintenance period for changing the gear oil ? is it a 30 wgt engine oil? and is there fill and drain plug ?
Search the forum, a number of posts detail how to change the gear lube.
i did, no matches found.
Sometimes you have to play with different keywords.
Here are a few to get started.
thanks, i found it, i really appreciate it.
schinia
what did you find
thanks
This is for 2016 and newer models
Suck out as much as you can and refill with 80/90 gear oil. until it starts to tun out of the fill hole. Unless you develop a leak there is no change out period. Lasts the life of the vehicle,
