I have a D&D motor do these setting look right?
F.No.  Function Description            Counts  Value        Units
1      MPH Scaling/Not Used            0       0            Cnts
.2      Creep Speed                     0       0            Cnts
3      Controlled Acceleration         15      15           Cnts
4      Max Armature Current Limit      218     218          Cnts
5      Plugging Current Limit          128     128          Cnts
6      Armature Deceleration Rate      50      50           Cnts
7      Minimum Field Current           70      70           Cnts
8      Maximum Field Current           255     255          Cnts
9      Regen Armature Current          218     218          Cnts
10     Regen Maximum Field Curre       255     255          Cnts
11     Turf Speed Limit                102     102          Cnts
12     Reverse Speed Limit             153     153          Cnts
14     IR Compensation/Not Used        0       0            Cnts
15     Battery Volts                   72      72           Cnts
17     Pedal Down Field Rate Gain      5       5            Cnts
19     Pedal Down Regen Decel Rate     255     255          Cnts
20     Pedal Up Regen Decel Rate       255     255          Cnts
21     MPH Overspeed/Top Speed Regula  245     245          Cnts
23     Error Compensation              10      10           Cnts
24     Field Weakening Start           65      65           Cnts
25     Monitor                         0       0            Cnts
26     Ratio of Field to Armature      87      87           Cnts
13     Rolling Radius in Inches        115     115          Cnts
16     Gear Ratio in Tenths            124     124          Cnts
18     Pedal Down Field Rate Offset    255     255          Cnts
