Good day ladies and gents. I have a few questions i am sure are super basic to most but i am totally new the GEM cars so please pardon my ignorance here. I have a few concerns with a 2002 gem E825 4 seater I took off my buddies hands for my daughter and I to mess around with.
#1 is if the cart is up on jack stands, should both front wheels be spinning at the same rate when you apply the pedal to the metal..i mean plastic or fiberglass whatever this thing is made out of lol. I was testing the load on the batteries (another issue i will address) at 5MPH when i noticed my pass side wheel acts like it wants to spin but doesn’t. It is free of the brake as i can spin it freely by hand. I just installed a set of disc brakes up front so there is a tiny bit of drag but i can push the wheel with one finger. The driver side is doing all the work. Is this the norm or do i have a problem and if so what is the remedy or test for the remedy?
#2 As mentioned in #1 i have some sort of electrical gremlin. I can charge the batteries to a complete charge (Quick Charge SC07210 charger date coded JUN-20) and take the cart out and run it down to lets say 80%. When i stop and turn the cart off and then immediately turn it back on again the charge says 40% and i go into a crawl mode if the cart moves at all. All the batteries are from 2024 and all individually read 13.1-13.3 on what the quick charge is sayin is a full charge. The load test i performed was simply done with a voltmeter on each battery with the cart running at 5MPH. There is some sort of huge quick discharge going on and I am not familiar with the intricacies of the electrical systems on these yet but would love to learn how they work so I can keep my daughter on the road safely ! Any ideas what could be causing this discharge? Also the little indicator light above my dash is cut/disconnected i guess due to the addition of the quick charge charger which has its own indicator built in? I would love to reconnect that if its possible with the aftermarket charger? Thoughts on the issue?
#3 My buddy gave me these parts to add on accessories like light bar, sound bar, portable Android, etc. I plan on using a relay between the key switch and the converter and then converter to the control switch box with its own fuses. Can someone explain where i would take the 72V feed from into the converter or would the converter already present on the cart (stock) be all i need to run into the switch panel and power all the 12V stuff? Here is what he gave me…
Any help on any issue would be greatly appreciated guys. If this is to many questions in one post i will separate them out just let me know fellas.
