Now, we want to introduce something about electric bike controller wires. Most of electric bikes now are using brushless motors, so the electric bike controller here means brushless motor controller.
For a normal electric bike controller, battery input cable, 3 phase cable,and 5 hall sensor wires are the most, then, we can see the cables for throttle, brakes, pedelect sensor, lamp, and so on.
For the controller with LED display, it will be a little complicated. The LED display can show battery power status, speed level, power switch and so on. You will see a extra connector for LED display. Now the 250w, 500w controller with LED display is popular.
The last electric bike controler is our controller with LCD display, this LCD display can read what eaxct speed of the bike run, the range, the battery status, and so on.
The above 3 brushless controllers are used mostly on currently electric bike conversion kits or brushless hub motor. ABOK motor can provide kinds of*bldc motor and bldc controllers. We have web retail shop too, which is good for those who want a sample first.Please have a try.You won’t be disppointed.
