kINGHAPPY, DAVE, WHOEVER.
Bought a 18’ Duffy Electric boat.   I’ll be keeping this puppy so need to figure  out a turn key lithium package. 36 volts.
Looking for range as the top speed is only 6 MPH.  GC batteries said to give 6 hours of operation.
Willing to give up marvelous technical gadgets for simplicity and minimum component count.
                Inwo
                    October 11, 2016,  5:20pm
              2
              What ah are the GC?
Is that enough?
What will the controller accept? For max voltage.
What is max current draw? Or hp.
The charger your sending me?
                Inwo
                    October 11, 2016,  5:34pm
              3
              If money was no object.
Drop-in lead acid replacement.
I was offered MN. dist. for these. About %40 off. Still too rich for me.
Actual turn-key.
              What ah are the GC?       105
Is that enough?       No
What will the controller accept? For max voltage.      ???
What is max current draw? Or hp.     3HP
The charger your sending me? China built electronic. 36 volt 18 amp
Will check out controller tomorrow.
                Inwo
                    October 11, 2016,  6:08pm
              6
              Ok, now we have a price point!
On the other end of the scale. I will give you 16 X 60ah pouches. 36v nominal. 24v to 44v range.
Actually a good option if you need less than 100amps.
My 48v pack:
                Inwo
                    October 11, 2016,  6:21pm
              7
              [quote=OLD HOUSEBOATER;33001]What ah are the GC?       105
Is that enough?       No
Will check out controller tomorrow.[/quote]
It’ll be hard to beat the leaf cells.
Need 10 I think. 2 of these.
              My  goals
Battery pack to outlast me. I’m 76
I already have 105 amps. Would like to increase that.
Would like to use regular flooded charger.  The one your going to fix for me.
                Inwo
                    October 11, 2016,  6:27pm
              9
              100ah lithium will be more than 100ah lead.
If you can make 44v work, this is what I have in my Gem.
It’s two 44v batteries.
One will give you 100ah @ 44v nominal.
Neatest package best bang for buck.
I have one you can test if you don’t mind shipping both ways.
              Don’t have paperwork yet.  Drive train parts on order. Hope to have in water in 2 weeks.
Will get make and model of controller tomorrow or next day. i’m buried in work right now.
                Inwo
                    October 11, 2016,  7:01pm
              11
              Let me know. The volt packs are neat. No assembly needed.
The only draw back is that they are assembled in 6packs and 12packs.
If you can make them work it’s a good deal.
