Just finished the disc brake conversion on my 2002 e4.
Brakes stop good but pull hard to the left.
I bleed and re bleed. The pedal is hard.
I replaces my Master Cylinder and rubber lines in the front.
I have 10 miles or so trying to wear in but no luck.
Any Ideas???
One of your rear brakes has wet linings
Give it a 150 miles to break in.
Rear?
I just put Disc in the front.
Can a rear axle brake pull the steering wheel
If one is dry and the other wet - the dry side will pull the wheel.
Still looking for ideas on my brake pull.
New install of Disc brake kit.
System bled.
Both discs working.
One side works better and pulls the steering wheel.
What is it?
[quote=wentbig;32372]Just finished the disc brake conversion on my 2002 e4.
[B] I have 10 miles or so trying to wear in [/B]but no luck.
Any Ideas???
[/quote]
Did you bed the new brakes and rotors?
If not, Google “How to Bed Brakes”. You’ll need to modify the procedure because of speed limitations, but you should get the gist of it.
Yes the bedding happened the first 10 miles in the hills.
I think the 2" wheel spacers are the cause.
The front end is 4" wider causing the shocks to compress to the point the camber is way out.
I will be changing to air shocks to correct the camber. Report coming next week.
