PayPal or a check.
David Bissen
Po box 496
Hokah, Mn. 55941
PayPal or a check.
David Bissen
Po box 496
Hokah, Mn. 55941
Morning David, I mailed the check today, look forward to receiving the Dave’s MM’s soon as possible. thank you.
On Wed, Aug 5, 2020 at 7:46 AM Inwo via Electric Forum <electricforum@discoursemail.com> wrote:
| Inwo
August 5 |
PayPal or a check.
David Bissen
Po box 496
Hokah, Mn. 55941
Visit Message or reply to this email to respond to Inwo, Red1.
To unsubscribe from these emails, click here.
Hi David, My package arrived today containing the magnet and a jumper wire, I don’t see any instructions, can you pls email me some installation instructions for these items. thank you very much.
| Inwo
August 5 |
PayPal or a check.
David Bissen
Po box 496
Hokah, Mn. 55941
The MM plugs into the harness on end of the motor.
The spoof plugs into pin #1 of controller. Remove p1 and replace with female end of spoof.
Wire that was removed plugs into the male end of spoof wire.
David, I was able to connect the harness to the motor but for the life of me cannot get the pin out of the connector, any ideas on how to remove this. I have removed the plastic housing around the connector and pulled on #1, it won’t budge. pls let me know.
On Wed, Aug 12, 2020 at 11:57 AM Inwo via Electric Forum <electricforum@discoursemail.com> wrote:
| Inwo
August 12 |
Release the red part that goes into socket.
Twist and pull wire to remove.
Push the new wire in the proper distance, same as others, and snap red retainer back on.
Google ampseal 23p connector for pictures.
David, Awesome info, thanks. I’ll give this a try tomorrow. Also, what is this “spoof” wire for? If I cannot get this wire / pin out, would it be OK to splice this in. Thanks for you reply.
Patrick
On Aug 12, 2020, at 5:28 PM, Inwo via Electric Forum electricforum@discoursemail.com wrote:
| Inwo
August 13 |
Google ampseal 23p connector for pictures.https://www.youtube.com/embed/K3d2u-a7udQ
Yes, you can splice it in.
It allows Gem to start at 10v more than normal.
You asked me to send the spoof. Are you sure you need it?
Running over 86 volts?
Hi David, Could use some guidance here and thank you for the video on the connector. I was able to get the pin out and connect the spoof as you directed. I ensured the number 1 female pin was at the proper depth, replaced the connector and what I am getting is a yellow wrench appearing in the dash and the Gem will not move. I disassembled everything to ensure it made contact everywhere and I did this three times w/ the same result. I took the spoof wire out, re-installed the original wire and the cart run once again. Sorry to bug you but need some of your expertise.
Thank you
Patrick
310 710 4375
On Wed, Aug 12, 2020 at 9:01 PM Inwo via Electric Forum <electricforum@discoursemail.com> wrote:
| Inwo
August 13 |
You need at least 78v for the car to run with the spoof. Are you sure that you need one?
What batteries do you have?
Hi David, Asking for your guidance, I’m having significant issues since installing the MM. My Gem seems to run much faster for a very short distance then shortly there after will not even go the standard 25mph although the battery meter still shows that it is just a bar or two shy of a full charge. I bought the cart with six new batteries as of March 2020, they are the Exide Nautilus 31 MDC. Your thought pls.
Patrick
1-310-710-4375
On Aug 14, 2020, at 4:21 PM, Inwo via Electric Forum electricforum@discoursemail.com wrote:
| Inwo
August 14 |
Chances are it is going in turtle mode.
Or that it will not run faster when below 72v.
Many are adding a 7th battery, so voltage never drops below 80 volts. That’s what the spoof is for.
You will still not have much range with deep cycle batteries. They are not designed for high current draw of an electric vehicle.
Thank you David. I do have a seventh battery I can add to the chain, will it charge along w/ the other batteries? I’ve got to find a way to maintain 35 MPH for short distances (less than 3/4 mile). Can you tell me the advantages of adding the “spoof”.
On Mon, Aug 17, 2020 at 8:42 PM Inwo via Electric Forum <electricforum@discoursemail.com> wrote:
| Inwo
August 18 |
need a 12v charger to charger the extra battery. Leave the current charger connected to the string of 6.
After adding 12v, car will not start without the spoof installed.
You should go to open forum where Rodney can advise. He does this all the time.
I can make this public if you want.
Yes pls
Patrick
On Aug 18, 2020, at 12:11 PM, Inwo via Electric Forum electricforum@discoursemail.com wrote:
| Inwo
August 18 |
David, Can you tell me how to correct the speedo so it reads correctly. Thank you
Change the speedometer to kph and it will read 0-40.
2005 and up it is changed by a long key press.
Earlier models need to be reprogrammed.
Sir, Not sure what a “long keyless” is? Thanks for the explanation.
Patrick
Sorry, auto correct.
Press the trip odometer button for 10 sec or more.
