Clicking noise driving me nuts
Have a clicking noise that appears to be coming from the front end. Increases as car speed increases. At top speed…,25…goes away. But that might be due to speed noise.
Used a stethoscope and the engine trans sound great. So I guess that leaves the half shafts which I recently replaced.
Any ideas
Did you check the wheel bearings?
Does it get worse when you turn, especially to one side vs the other?
Half shafts are known to make clicking noises but since you just replaced them and I would hope that’s not your problem. See if the noise changes while going around corners. If it does than there’s a good chance it’s a bad wheel bearing. You can also jack up the wheels and spin them and see if you can hear or feel any roughness.
Thanks guys…I’ll check it out farther
I guess a farther question would be…if the half shaft is clicking does that indicate imminent failure
