I have recently acquired a 1975 CitiCar, and I’m looking to replace the original charger. The car has eight 6V lead-acid batteries wired in series for 48V total. Ideally, I’d like to be able to charge using J1772 and a normal 110V plug, assuming the cost isn’t prohibitive, and I’d like to be able to reprogram the charger for Lithium batteries, in case I choose to go that route once my existing batteries reach end of life.
I’ve looked into a few options, and Delta-Q, Elcon, and Noco have all looked like potential options, though I don’t think that the Noco will work for J1772 without something custom. I can’t get a solid answer from Delta-Q or their distributors about what is required to use a Quiq or IC charger with J1772, unfortunately. I have also seen a number of threads on here like this one for a custom J1772 solution.
Does anyone have suggestions?
Tom
