Any one know how to tell what firmware version is installed on your 24T? I see there are some newer (i think) firmware available for the LCD and the main unit but there are no release dates for the firmware and I can’t find out where in the unit it can be displayed.
It flashes on when booting up.
Thank you Dave - hope you had a good weekend.
Where did you buy your BMS -24 from?
I need to type 20 characters so now I can say “David”
David: what does the new firmware do for the BMS 24?
Version History
Software Version Description
V1.05 Released first time
V1.06 Fix press STOP enter into sleep mode, and Beeper & LED warning.
V1.07 Support LTO battery, model is BMS24T
V1.11 Negative temperature can be measured.
V1.12 Add charge protection, Don’t charge under 2℃
V1.13 (Hardware V2.2) Add display module, improve voltage bar graph display, the lowest
negative 20℃ can be detected
V1.14 for LCD Fix the charge and discharge WH bug
V1.15 for LCD SOC can be setup to 0%
V1.16 for LCD Start automatically on battery type and cell count setup interface,
need not press START button.
V1.21 for LCD
Fix a bug when display temperature difference at F.
Fix a bug on adjusting balance start voltage on LiTo battery
Add balance control item in storage status on Program Setup interface
—balance in Storage on or off
– balance in Charge on or off
– balance in Discharge on or off
Charge status: charge current displayed over 1A
Discharge status: discharge current display under-1A, such as -10A
Storage status: current displayed between -1A ~ 1A
So current shunt and current sensor wire must be connected to BMS main unit.
Improved SoC of LiTo battery
V1.22 for LCD and
V1.18 for main unit.
Improved SoC arithmetic
Fix a big when over discharge resume
Version 3 is out but I don’t know if it can be loaded onto older 24T’s or not???
Version History
V1.21 for LCD
V1.22 for LCD and
V3.0 Update hardware and software at the same time. V1.22 version discontinued.
I haven’t looked at the web sit in a while. It lists the revision history.
I sent the question to Jason Wang who is usually pretty quick to respond.
王军荣 <[jasonwang3a@163.com
This is Jason Wang’s correct email jasonwang3a@163.com
Got this reply from Jason Wang on the question of upgrading the firmware on the BMS-24T from 1.22 to 3.0:
NO, 1.22 and 3.0 have different hardware, on V3.0 manual, you can find the update information.
thanks. Jason Wang
