2016 E4 What size tires should i put on Radials are not Wanting best ride
thanks
thanks
Well I’m a stock kind of guy. Standard size is Street rated 13-inch Steel 4.5-inch ET11 155/80R13
(Optional 14-inch Aluminum 4.5-inch ET11 165/70R14).
But you can also use this tire conversion calculator.
are you planing to go stock?
stock do you mean oem ,if i can find a set
How much Where are they What size tires Do you have the lug nuts
Im in South Florida, Oem from Polaris tires 165/60/14
Sorry no lug nuts, I’ve used them With the new set But you can buy them here
$600
