I removed the engine to replace the bumper, and found a very strange build up on the coil. It looks like cement and is incredibly hard to get off. I’ve left on for now, although I’m assuming I should remove it. Has anyone seen this before?
Leave it alone.
wwwwwwwwwwww
That is where the last guy put his chewing gum.
It also balances the rotational assembly.
You could also do with a little dab of assembly paste in there. The splines are looking a little dry.
Dave is vise
Just keep leaving it alone. Its a special epoxy for ballancing rotating components. Its very / hea
Y heavy Think "kind of litke a tire weight.
Unless you do something thhar causes a physical dam
When did you pick up the cheap German accent?
Cracked cell phone screen and kind of faded off to sleep.
