Hi,
Im currently building a Ford Ranger PU EV. Got a battery question. What is the difference between Trojan T105 and T145. I see the T145 has a little more amps but is that the only difference? Can you get more cycles out of it or is it only the amps. I am going to use a 144 volt system so would it be better to use 20 T145’s or 24 T105’s. The weight is about the same so I was wondering if there were other advantages that justify the 60 dollar difference in price?
