TROJAN BATTERIES APPLICABLE TO USE IN GOLF CARTS
First number is type, second is model, third is Amp rating at 20 hours, forth is volts, fifth sixth and seventh are L x W x H and eighth is weight.
When considering aftermarket batteries you need to look at the TYPE, AMPS at 20 hours and WEIGHT. If some one is trying to sell you a 260 amp battery and it only weighs 60 pounds – RUN.
East Penn and Johnson Controls all make Comparable batteries that are equivalent to the Trojan in size, type, and capacity. All battery manufacturers furnish private label batteries to many sources.
Battery sellers price the battery to suit their profit margin. The exact same battery can be priced twice as much as the same model from a different seller.
Ask the seller who manufactured the battery and match the specs to this information so you don’t get cheated. High amp rating and heavy weight is GOOD!
6 VOLT DEEP-CYCLE FLOODED BATTERIES - with T2 TECHNOLOGY
GC2  T-605  210  6  VOLT  10.30  7.11  11.07   58
GC2  T-105  225  6 VOLT   10.30  7.11   11.07  62
GC2  T-125  240  6 VOLT   10.30   7.11 11.07   66
GC2H  T-145  260  6 VOLT  10.30  7.11 11.90  72
PREMIUM LINE - DEEP-CYCLE FLOODED BATTERIES - with SMART CARBON™
GC2H T-105 RE 225 6 VOLT 10.30 7.11 11.67 67
8 VOLT DEEP-CYCLE FLOODED BATTERIES - with T2 TECHNOLOGY™
GC8  DC-8V 160  8 VOLT  10.21  7.06  11.14   61
GC8  T-875  170  8 VOLT  10.21  7.06  11.14    63
GC8H  Traveler 170  8 VOLT  10.21  7.10  11.90   70
GC8  T-890  190  8 VOLT  10.21  7.06  11.14  69
Ranger 160 8 VOLT 10.21 7.10 11.90 76
12 VOLT DEEP-CYCLE FLOODED BATTERIES - with T2 TECHNOLOGY™
30H 30XHS  130   12 VOLT   14.00   6.73   10.07  66
30H 31XHS  130   12 VOLT   12.97   6.75   9.58    67
N/A T-1275   150   12 VOLT   12.96   7.13   10.71   82
MARINE/RV 12 VOLT DEEP-CYCLE BATTERIES - with T2 TECHNOLOGY™
30H SCS225 130 12 VOLT 13.92 6.75 9.95 66
DEEP-CYCLE GEL BATTERIES 6 AND 12 VOLT
GC2 6V-GEL   189   6 VOLT   10.25   7.08   10.82   68
31 31-GEL 102 12 VOLT 12.94 6.82 9.64 70
12 VOLT DEEP-CYCLE AGM BATTERIES
GC12 12-AGM -   140   12 VOLT   13.54   6.76   10.88   100
31 31-AGM -   100   12 VOLT  13.73   6.80    9.16     69
