Navitas does not have a motor profile for the 8kw motor - that may be a challenge.
Correct. I would just put a new motor in.
They have a 5kw and a 7kw motor so something should work
Sevcon controller programmed for Kinetek motor and Anvil throttle.
$1200 refundable.
But I would wait for tips from the first one I sent out.
Connect these wires.
I just put in a new throttle and same issue.
I am not sure if my My motor is bad. The controller is a brand new kinetek so the only thing left is a speed sensor and motor.
I get a new speed sensor tomorrow so if that fails i will probably need a motor
If i jiggle the speed sensor then i can get it to run with the throttle depressed. I assume thats the problem then.
When you give it a push, then you feel that accelerates struck like normal??
Maybe weak batts?
Yes accelerates fine after i push it only needs an inch or so to get it moving. Or if its jacked up and i jiggle the sensor.
I check all the battery cables to make sure their tight as we’ll.
Trying to play with getting this dongle to work in the mean time.
See if sensor is fed by 5v or 10v. We found that they like 10v better.
15v.
I think i fried my controller tring to get the pc to program it.
Now it gives me a high phase fault.
Put the old one back in and it works.
Turns out it was a bad speed sensor.
I am ready to give up on the kinetek
