My headlights are not working at full strength. And when I put a bolt meter on them they are showing 9 volts at them. Same Go’s for the 12 volt accessory out of the DC to DC converter.
We had swapped out a know working DC to DC converter and we had the same 9 volt output.
What is the output voltage of your converter with nothing turned on. Is this a new condition or something you just noticed. Do you have aftermarket lights etc. The DC/DC converter is sized for stock load without much reserve.
The condition developed after I installed my charger incorrectly so I think I zapped somthing. The output of the converter is still 9volts with nothing turned on.
Do you have a picture or model number?
Send it to me if it’s bad.
Shouldn’t be too hard to fix if it’s just out of regulation.
Possible adjustment inside.
Or overheated current shunt resistor inside.
It’s VERY possible I shorted or burned something up inside it. All this started after I did the the Dammage to my Delta q charger by hooking up the 72 volt innerlock to ground. Is it possible that the interlock Relay you set up for me is playing havoc on 12 volt system?
Remember my car needs a Ground for the innerlock to work.
Pin 1=72B- (not grd)
Pin 12=72B+
Pin 9+10= 12v+ always on (limited power for radio)
Pin 7+8= 12v+ on with key
Pin 4+5+6 12v ground
Pin 3= 12v+ from key (turns on 7+8)
