Hello all, I am looking to build a small reverse trike. I also attached a quick schematic for the basic idea of how I plan for it to look.
I need some help with the electrical engineering of the motors and batteries. My knowledge base is not very good (even after tearing apart this website) so if I could get some educated feedback it would be greatly appreciated! All comments are definitely appreciated as well!
So this is the deal:
I purchased 5, 24v motors off of craigslist, up to about 220 watts at the maximum 27 volts and 8.2 amps. I am planning to affix gears to each of these motors and connect them to a single drive-train. This is the problem I am thinking about though. I know I can run the motors either in series or in parrelel from the battery but doing so would either result in a voltage drop across the motors in series or a significant amperage consumption in parallel. Is it more efficient to run these motors in series or parallel?
Next question, I am planning on getting a small controller for the batteries, probably 30amp or so (but I guess this depends on how I wire the motor), will the controller work effectively if I run the motors in parallel? Also if I don’t use a controller, what will the effect of that be?
Other aspects that might have potential problems: I plan on using a potentiometer for the throttle as well as 2, 12v lead-acid batteries for the batteries.
Let me know what you guys think and thanks in advance!
