2012 GEM Troubleshooting- No movement
Please don’t let me interrupt Byron’s stream. I’m sometimes scatter brained!
Ok, to complete the open items here:
The pedal assembly had 2 or 3 cold solder joints that i got sorted out and put back together. It is acting as a hall sensor as opposed to the original resistive type.
The other issue was the main 23 pin connector pin on pin 9. Once I got the prongs on the pin reseated, things fired right up.
Thanks so much to @AssyRequired @Inwo and @JarJarJava for all the help and insight. Ill definitely be back with more questions and hopefully I am able to reciprocate with help as well. Much appreciated!
