We have a 2011 Gem E4 4 door that is having starting issues. We replaced all 6 batteries recently. When the unit is plugged in, it charges. When you turn the key to on, nothing “starts up”. We replaced the fuses recently as well and the master switch is on. Any idea on what could be causing this issue?
This is a problem that has happened to many members. Before we get into a long discussion please spend a couple of hours reading the GEM section of the forum for information that matches your condition.
The most common cause of no go is the parking brake switch being defective or not adjusted properly. Bang it down hard to the bottom a couple of times.
