Hello all,I have this icon and code on my display. Cart will not do anything. HELP
Is your cart plugged in? (charging)
It thinks it is…
No it isn’t plugged in
Have you done anything new to the car lately?
Worked on anything under the hood?
You need to check the status of the green interlock wire.
Nothing has been touched,just unplugged it from charging and Nothing.
So what am I looking for on this green wire? What voltage should it show?
Green wire from charger is B+ voltage…
Needed to turn off plug icon on dash and allow car to run.
Does charger show fault?
In other words- We need more info to make an educated assessment of your condition.
Do you remember where your Charger Display is located? (not your dash display). When you plug your car in to charge, What is your charger display showing? This might be a clue to direct you what to look for next.
It’s not what you should see on it, but more that it is plugged into it’s mate. If you want to take the next step and measure for B+ on it, This would be an added bonus. (that wire needs to see B+ for the car to unlock and go.)
Ok I will plug it in tomorrow and check the charger display on the actual charger. I will report back after I ck this and voltage on green wire.
Ever hear the expression “I had to light a fire under their ass to get them to move!” ?
It works on Gems too. Literally…
Hey @gofast67 –
Where did you go?
What is your status?
Wait, “gofast”'s GEM wont move?
Hillarious. Hiw did i miss that?
