2010 EL parts
Anyone have Ebay links to front end parts?
Look like arctic cat bearings… 0402-275 55mm 30mm 30mm ?
Seals 55mm 40mm 6.5mm Will 7mm wide fit?
Boots. Are inner and outer the same? 70mm X 22mm.
Steering boots?
I’m going to search the “parts” thread. See what I can find there.
All that stuff should be available on Ebay
Finding the right part is not easy.
Cv boots are listed as inner or outer. Don’t see the difference.
Boot? Anti Dust Outer Drive Shaft CV Joint Boot Shield Cover Black for VIOS | eBay
Bearing? New Arctic Cat Wheel Bearing 96 97 Bearcat 98 04 250 300 400 500 0402 275 | eBay
Seal? AVX Shaft Oil Seal TC40X55X7 Rubber Lip 40mm 55mm 7mm Metric | eBay
Steering boot? New Polaris Boot Steering Rack End 5414411 2012 Gem Sportsman 800 | eBay … or … New Steering Rack Boot Left or Right 1228425 | eBay
Here is the Polaris rack boot from forum parts list…
Polaris Ranger Steering Boot Rack and Pinion Gear Replaces 5412013 2004 2012 | eBay
And the shaft boot…http://www.ebay.com/itm/2006-E-Z-GO-ST-4x4-Golf-Cart-HD-Front-Inboard-CV-Boot-Kit-/271550677240?hash=item3f39ae80f8:g:1AkAAOSwbqpTxreS&vxp=mtr
Why inner? Both the same???
The inner has a 3 bellows configuration because it flexes less. I use the universal fits all and cut off the portion I don’t need. Never had a problem.
You need boots already???
Yes, do you have to take shaft apart?
These are 22mm X 70mm which is correct. Don’t know about length.
$7.59
Still looking for bearings.
Have you tried sealed bearings?
Yes note: late models come apart on the inside end. Are your boots bad? Usually they will last ten years.
Boot change is a messy *****
Yes, this is the Texas 2010. Also bad on the Wi. 2008.
I have a bunch of 55 X 30 X 13sealed bearings.
Tempted to use a pair to replace 55 X 30 X 30.
Bad idea?
Think I can find them for $15 each.
Stock are angular double row I believe.
These came in fast and fit perfectly. 2010 EL
Waiting for shaft boots.
Exact fit steering rack boot.
Front wheel bearing.
Front wheel seals X2.
Boots were a good fit.
7cm end was actually 7.4cm. Big is better. Clamped down fine.
Recommend them @ $32 for 4. Seem to fit both end fine.
Picture in post 7.
