2009 GEM car led panel flashing...won't run
All the dashboard icons flash and the R DL DH
Batteries seem charged but something’s gone awry! Continuous beep when brake released.
Is there a way to add video to post?
Hi
do a search here on forum…
turtle flash
and you see some other with that problem
I just found couple postings with same problem and read…looks like I probably need a controller rebuild? We shall see… thanks
Hi
it can also be some problem with loose cable at the controller
if i disconnect the big connector with all wires on my controller mine display also flashes
