I just purchased a 2007 Ruff and Tuff. I’m guessing it is the cruiser model. It is a 2wd. The previous owner had the controller replaced with an alltrax 48400. Does anyone know what the motor specs are? Also, what is the stock top speed on the R/T? This one will do 17 on flat ground. I plan on adjusting the controller to limit the torque in reverse. Right now it takes off way to fast in reverse. I would also like to make sure the torque settings aren’t set too high. I would like this cart to last as long as possible.
Thanks,
Kyle
