@lithiumgods - That makes a lot of sense. Do you know how I get a software upgrade and new profiles loaded? I was thinking of picking up a QuiQ programming kit and doing it myself… Can I do that on a GEM charger?
Well, good news - After manually charging each battery for a couple of hours each, I was able to start a charge, and I got the 80% light after about 3 hours. Then left it charging overnight and I got a green light this morning! Battery voltages are: 13.27, 13.14, 13.21, 13.20, 12.89, 12.88, and the main contactor has 79.0. I actually unplugged and re-plugged in the charger, and got another green light after about an hour. So that all feels good.
The odd thing is that when I start a charging, it will go through the LED cycle, turn on the AC light, and then I get a flashing light on #1. It will eventually go to a solid #1 after a couple hours, and then shift back to a flashing #1, but I have never seen it go to #2, 3,4,5,6. Is that normal?
I am considering shifting back to profile 13 to see if I get different results - what do you all think?
Thanks a ton for all of your help - this group is awesome!
Update1 - Recalibrated the SOC - thanks for the suggestion @Inwo. Went for a nice 10 mile drive… all was going well, the battery LED had dropped to about 60%, and then it suddenly went to one red bar, and turtle mode. Got it back home and plugged in again… we will see if it picks up the charge again, or if I get 4 blinkng lights again!
Update2 - Back to square 1 - I have the 4 blinking lights again. I am inclined to think @LithiumGods is correct…
