Does anyone have a wiring diagram for the PWB? Repair Manual doesn’t have one that I saw in the section for the PWB.
I have what appear to be two different ground wires with a couple attach points hanging down in the wiring near the PWB. On the PWB bottom right corner where the fuses are, to the left of the fuses a spade terminal that appears either of these grounds could connect, but not sure if they should.
After putting body and all pieces back on, when I kick on the power I am getting an electrical crackling sound. I am seeing voltage jumping between the two fuses on the PWB, so not sure if it isn’t grounded properly or for some reason I need to seal between the fuses with some liquid electrical tape.
thoughts?
Thanks,
M@
