Just got this and The speedo head doesn’t tell anything. its blank. Doesn’t charge either/ We put new batteries and everything else works great. runs down the road great. Thanks
Inwo
July 27, 2019, 12:01am
2
Head has a data cable to controller.
So head, cable, or controller is bad. See if it’s plugged in on both ends.
When I plug in to charge. I get Yellow flash then green flash with alarm. I tried new controller and head…
Inwo
July 27, 2019, 2:48am
4
My suggestion was for the dead head. Must be the cable connections.
Charger, I don’t know!
This is a list of error codes for the Zivan charger used on many pre-2005 GEMs.
Daniel
blank: normal if charger unplugged no AC voltage check line voltage and charger internal fuse
red flash: battery presence DC voltage out of range close master disconnect, check battery voltage and polarity
yellow flash with audible alarm: thermal sensor failure thermistor out of range check connection and resistance of thermal sensor
green flash with audible alarm: charge time too long, charger t…
