You all have been very helpful in my quest to fix some issues with my first GEM. I cannot find a solution to this issue on my 2000 Gem E825 E4:
- -04 code on display stays on all the time, key on or off no difference…
- charger does charge batteries with master switch on…
- operates with key on or off… (two wires on back of ignition switch but switch has three studs)
- I hear the solenoid kick in when I plug in charger…
- when the charger has finished charging and is off I unplug the charger (-04 dash codes still on) until I turn off master switch…
- when I turn on the master battery switch, the dash error code is displayed and when I release the parking brake I hear solenoid kick in (with or without the key turned on)…
When I head out on the road the GEM runs great, both in turf and road mode. all 12 v powered items operate (wipers, turn signals, horn, lights,etc…)
It still rides rough but working on replacing shocks, bled the brakes and got a better peddle movement will do it again next week.
I got a new replacement emergency brake switch which did not make a difference in operations or resolve issues when installed.
Any help or suggestions would be helpful, THANKS
David
