I’m not understanding how the axle is connected to the transmission. I see a snap-ring on the transmission seal, but the axle seems to be designed to slip over a shaft. Is it supposed to slip off or do I need to remove that snap-ring first? I read the manual and searched for an answer but I’m not getting it.
Thank you for the answer. I’m replacing the axle so I tried pulling it hard. I also tried using two large screwdrivers to apply outward tension while pulling on the axle shaft. I’m having no luck at all. I don’t want to damage the transmission so I haven’t resorted to a slide hammer yet…
Got it! Once you explained the design, I figured there might be some rust in there. I bent the little tube back on a can of PB Blaster and gave it a few shots. A half hour later, as I was showing my wife what I’ve been doing for the past 3 hours, it popped right apart.
