I’m having trouble separating the motor from thedifferential watched utube looked easy, any thoughts would be appreciated,
If it is really stuck remove the 2 screws in the back of the motor and pull the housing off. You will then be able to get at the joint and pry it apart.
that’s what I thought, thanks from Harry
