I am considering replacing the half shaft on my 2000 2 seat GEM.  The steps in the manual seem a little confusing.  So I need to remove the retaining nut form the wheel assembly, and then I assume there is enough flex to pull the half shaft back to get it out and away from the wheel assembly,
Then I need to get it out of the differential by prying it away with short pry bars ?
Is there perhaps a youTube video out there for this job?
Any insight would be appreciated.
