I have decided to install a 300a continuous duty battery switch under the seat, it has a 500A peak rating and will be installed at the battery 4 location to meet the 48VDC requirement. I talked it over with my electrical engineering friend and I have many years of designing Solar systems neither of us can figure out why they would install something so underrated or why this should not be a safe alternative. My one concern is the amperage through the negative shunt however since I broke the stud off I am not using it anyhow. Battery voltage is being monitored through a Batt Six and current will be monitored through the digital battery management system so I do not care if the dash meter is working or not as I don’t believe it anyhow.
You might want to think about it. The PDM (Power Display Module) is a $900 dollar piece[/quote]
from what I can see the only reason power is flowing through the PDM is for current monitoring for battery state of charge, the Motor controller has its own current sensing for control and protection. What my plan is to do is move the main power connections to the motor controller and then come off of it with a lower rated fuse to the PDM to protect it. I have a spare PDM board that was bad, one of my EE friends reworked for me as a spare I am going to see if the shunt circuit is a standard resistance, because if it is then I will run an external shunt on the battery feeds into the motor controller just so that the gauge works. If there is something I am not seeing here please feel free to say so, I am looking at this from a pure electrical engineering standpoint rather than a NEV application. I still do not see how having a rating of 1/3 the protected capacity makes sense in any application. I am engaging the conversation because if this works out then it means that we can utilize the current capabilities needed for the bigger motors under load safely. One of the other thoughts I had is that if this switch has been getting hot under load the internal resistance is obviously high therefore reducing performance. Let’s think through the entire system and not just one piece of it.
[quote=Inwo;29799]Got it today.
Hack in progress.[/quote]
I just want to say thank you as a hacker myself to resolve issues that dealers want insane amounts of money to fix, with other folks on here like Rodney this has become a fun challenge and I think we will end up with some pretty solid solutions for those who want to fix things so they stop breaking. I don’t know much about motors but when it comes to electrical system design I can hold my own. I would be very eager to have the wireless HD shunt setup if you end up with it working properly.
so I got to run the car this weekend with the new disconnect switch installed, absolutely ZERO heat build up in the switch so everything seems good there, now I have a hot cable going from the fuse to the #4 battery, there looks to be some corrosion in the cable so today I will stop by West Marine and pick up some cable and crimps to get that fixed up. I am also going to change the style of fuse as the one installed is a bit gunked up looking even after I cleaned it up.
Hello my friend. I bought a GEM with the same problem. Make sure that ALL YOUR LUGS are tight. Usually when you take out a breaker it’s due to a " heated surge ". I put a main Albright disconnect and mounted securely. That breaker set up is the cheesiest piece of poop. ZERO issues. ***** MAKE SURE YOU DISCONNECT THE MAIN POSITIVE AND NEGATIVE TO YOUR BATTERY PACK **** reason being your breaker will be bypassed for checking. Mine surged so bad it actually took out the contactor. The solenoid was engaging but the main lugs were toast. Best of luck !
