Specifically a 2010 eL, but IIRC 05-12 are the same.
Does anyone know the oil seal trade number / size for the front hubs?
I found the bearing size, DAC305530/25,2RS, but I can’t find any oil seal info other than the GEM & Polaris part numbers.
Is the passenger side bad?
Seems I changed the drivers side.
Maybe both. I need to look if I have one left over.
Maybe other way around?
The bearing came apart at the inner race on the drivers side when I tried to take the hub/rotor off. Passenger side the hub came off without incident.
Related question, for the guys who have swapped transmissions out, am I missing something obvious, or do you have to undo the pinch bolt at the ball joint and partially separate the knuckle to get the half shaft out?
I had to completely remove the bolt from the knuckle that holds the ball joint on and pull the knuckle away to jet the cv joint out of the knuckle/off the transmission.
Found the seal size - it’s a TC 40 x 55 x 6
avxseals.com has them a couple cents cheaper than nevaccessories
They do have some lower cost shipping options, like first class mail for $3
And they are in Orange County CA so depending on where you are, they might get there a bit faster than from AZ.
I know, it’s basically splitting hairs.
Hoping I get them by Friday or Saturday. Be nice to finish pulling everything on this cart and finally get the new gearbox and AC motor in it.
